Nothing in objects only a tree - please help
I only have a tree in my object, however, I see that the Library Manager has a whole lot of objects in it.
How can I get all the items in the library to be accessible in the object section?
I have ArchiCAD 20 - student version.
4 REPLIES 4
From your description I am not exactly sure what the situation or issue is.
Could you post one or more images and explanation of what you are trying to do in which Dialog?
Thanks for the reply.
So this is all I can see.. my default seems to only be a tree. Not sure why.
I hope this makes more sense?
Erwin Edel
Those are just the saved favourites in your template. In the settings dialog you can see all the availabe objects.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
That Palette shows only the Favorites defined for the Tool.
In order to see all available object in the Library activate the Object Settings Dialog by either double-clicking the Tool in the Toolbox, or selecting the Tool in the Toolbox and then clicking the Tool icon in the Info Box, or selecting the Tool in the Toolbox and pressing CTRL+T on the keyboard.
