Object Origin Keeps Moving
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2004-04-27 11:48 PM
‎2004-04-27
11:48 PM
IF A < 30" THEN PARAMETERS A = 30"
Whenever this line kicks in, the object resizes, but it moves the lower left corner, keeping the position of the hotspot that was dragged. How can I lock the position of the lower left corner? I only want that corner to move if the user explicitly selects its hotspot.
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-04-28 02:00 AM
‎2004-04-28
02:00 AM
Jay,
Is there a particular reason you want to use the "Parametes" command?
Wouldn't writing in the Master Script if A<30" then A=30" do the job?
Peter Devlin
Peter Devlin
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-04-28 02:06 AM
‎2004-04-28
02:06 AM
Try using the RANGE setting. Such as:
VALUES `A` RANGE [30, 1000)
This has the cool effect of snapping automatically to permitted values. It's fun to play with and actually pretty useful too.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-04-28 03:06 AM
‎2004-04-28
03:06 AM
Jay,
Matthew is right the "values" command does the job.
Peter Devlin
Peter Devlin
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-04-28 05:23 PM
‎2004-04-28
05:23 PM
Matthew wrote:Not quite what I was looking for. Perhaps a better explanation of what I'm trying to do.
The GDL I'm building will draw restroom stalls that conform to ADA. If you stretch the object in the A direction, you get more stalls and/or urinals. I want to keep people from stretching it smaller than an ADA compliant stall. So I used the simple statement "IF A < ada_min THEN PARAMETERS A = ada_min". Unfortunately, when this line of code executes it doesn't reposition the hotspot I was just dragging, it moves everything else (see graphic).
How can I get the hotspot labeled "H1" to stay where it is unless it is the hotspot being edited?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-05-26 06:14 PM
‎2004-05-26
06:14 PM
Jay,
To fix your specific problem try this:
IF A < 30" THEN A = 30"
PARAMETERS A = A
Or/And...
IF A < ada_min THEN A = ada_min
PARAMETERS A = A
Be sure this is in the "Master Script"
PARAMETERS A = A
Or/And...
PARAMETERS A = A
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
AC 5.1-25 USA
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-05-26 06:26 PM
‎2004-05-26
06:26 PM
I think you will have problems as long as you use the A parameter. ArchiCAD automatically adjusts the overall part based on A and B values and assumes that the last place the user clicks is important (not a mistake). If I am wrong, I would love to know how to control this.
You can get the result you want with an active hotspot (the diamond shaped type programed into the GDL).
