2018-09-10 05:53 AM - last edited on 2023-05-23 04:10 PM by Rubia Torres
2022-12-20 06:14 AM
I have this issue as well. Surprised no one ever answered it yet. Any ideas.
2022-12-26 09:53 AM - edited 2022-12-26 09:53 AM
This is a limitation in Archicad. It will look which Zone the Object is located to and that Zone's info with be returned in the "Related Zone" Schedule fields. However, if multiple Zones overlap, Archicad has no way of knowing which Zone you want to use so it is random which Zone's info will be used.
There is one specific case I can offer a solution to:
If you use Zones to model the gross area of a Story (and that causes overlapping Zones), I usually recommend that you should use Morphs to model those gross areas because the area of Morphs can be schedule by Story. This way, you will not have overlapping Zones and the issue is avoided.
