hi SenecaDesignLLC,
hi all,
thx for the hint. I am affraid that that way would consume way too much time, when it comes to objects like this Radiographic Unit (image 1) ⦠and we have a lot of such objects (~700)!
Our optimal workflow would be:
- Purchase 3D Model from online libraries or remodel object by our own.
- Select 3D Model
- Edit -> Libraries and Objects -> Save Selection as -> Object.
- Do the saving ā¦
- Edit -> Libraries and Objects -> Open Object
- Manual adapt the 2D View (image 2) so its readable in the floorplan ā and thatās the problem. AC does not let me do that.
Any idea how to get to get to the result? If I have to change the workflow also ok
š
We just need a way to get 3D Models with customized 2D views together without the need to code. Because it takes much much too long and the process must be doable for more colleagues so they can do their project embedded objects by their own.
I become a bit worried that that issue becomes a show-stopper in our AC implementation. You know of external tools or addons that can help us maybe?
Again thanks for any hint and/or suggestion!
Florian
