jakubc7
POLY2_B object with ability to add nodes
I am trying to make an object (POLY2_B seems like a suitable command).
It is to be a 2d shape, straight lines, always enclosed, but with an ability to add nodes without going into parameters.
I have seen it done on an object ... code locked where there is a node in the middle of each straight line, if you click it and drag it at creates an additional node/line.
I want to be able to get the area of the closed poly but i imagine that wouldn't be a problem.
Is there a simple/obvious way to do it or do I need to think outside the box here? Any advice?
Jakub
ArchiCAD 10 - 29 | Windows 11
Lucid Design Studio | Perth, Western Australia
2 Replies 2
Miha Nahtigal
Something like this?
https://www.dropbox.com/s/de0vfdqdfkrx7ua/Poly%20Area%2001.gsm
BIMquants - Free Plugin for Quantities and Costs Estimation in Archicad | BIMrender - Free & Open Source Plugin for AI rendering in Archicad
jakubc7
Thanks vuego, it's exactly what I was trying to achieve.
I'll study the code to understand how it's done.
Thanks for your help.
