2019-10-08
07:18 PM
2023-05-26
11:10 AM
Rubia Torres
Solved! Go to Solution.
2019-10-10 05:31 PM
2019-10-09 05:15 AM
2019-10-09 11:39 PM
2019-10-10 12:00 AM
4hotshoes wrote:
Using D1-23, I changed parameters to a desired setting. I loaded the parameters with the "suction" tool. I opened the Door Settings and found the D2-23 (dbl door) and tried to inject parameters with Control-Option-click on the D2-23 door. but nothing changed that I could see. The syringe icon did not show.
What might be happening? BTW, this did not work in AC22 either.
2019-10-10 02:59 PM
2019-10-10 05:31 PM
2019-10-10 05:43 PM
2019-10-10 06:31 PM
James wrote:So if I change my favorite "Fixed Window" trim to be wider and Update the Favorite, I can continue to use that same change and update each favorite window I have while the Window Tool Setting is up and thing my favorites?
If you want to update an object favourite without clicking on it, hover over the favourite you want to update and click the “...” circle icon, from that menu you can use redefine. This will update it without having to select it first.
2019-10-13 04:17 PM
4hotshoes wrote:The redefine will apply all settings that are active, including the object itself so not just the size, another way to update a favourites content is to use the favourites palette, right click, and use “Edit”. This will open the relevant settings dialogue, then make changes to the favourite, then click OK. You can use “Edit” on a multi selection as well, and if you change the size of A or B for example, only that change will apply to all those selected favourites.
2019-10-14 03:10 AM
