Password protection of 16 objects = a problem
The new password protection for objects created in version 16 is a nice option and provides much more security than the old "hide scripts".
So I welcome that, but it does cause one slight problem that the old "hide scripts" didn't have.
Now when you password protect an object you can't open the object without that password.
"That's the whole idea!" I hear you say.
But now we can't even open the parameter list to set default pens, fills line types etc., if they don't work in our customised templates.
At least with the "hide scripts" option we could see the parameters and would be able to change them to suit our custom setup and then re-save the object.
So now we have 2 choices.
Contact the person that created the object and ask them to save a version with custom settings - I'm sure they would love to do that for everyone.
Or use the object as is and change the settings everytime you place it.
Even selecting the object and saving that selection as a new object so that you have a new unprotected object that "Calls" the protected one doesn't work.
Anyone have any ideas for a solution?
I might have to make a wish for this one.
11 Replies 11
Thanks Laszlo.
Very much appreciated.
Frank Beister
Let the final user access at least to parameters.
Let the developer decide, which access should be possible.
Parameter access allowed per default, but possible to turn off.
I do not want to give access to all parameters of my objects, because the given away version is sometimes locked to certain settings and only the commercial one has free access to all parameters and settings. And I do not want, that my objects are translated in every language. Public domain is another thing, but if I give it for a feeless usage I, as developer, want to keep control.
Hiding all scripts isn't a good solution also. A lot of settings in my objects are done by numeric values, which offer full options first in the user interface. Optional access to the user interface would be appreciated and locking direct parameters access.
But you are right. The way it works now, is not very good.
