Place objects with random scale and rotation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2021-07-16
07:43 PM
‎2023-05-23
04:03 PM
Rubia Torres
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-16 09:08 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-19 11:22 AM
A couple of ideal solutions would be:
Quickly define specific parameters - something like in ZBrush, where you click to define the position, then drag to define size, then drag again to define rotation
Random - activate a 'Random' mode (similar to activating a Relative Construction Method) and specify deviation parameters for Rotation, Scale and Translation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-19 01:49 PM
JohnJay wrote:I gave PARAM-O a try and it looks like it is doing the trick.
Is there a quick and easy way to place - say - a tree and with each click define a random rotation and scale, within given parameters (e.g. random rotation 0 - 360 degrees, scale +/- 30%)?
Open the gsm file inside PARAM-O and change it to your desired Tree object.
Hope that helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-19 02:42 PM
There is a download link to google drive in the description.
It allows different methods of random distribution or scatter.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-19 03:21 PM
Erwin wrote:This looks a lot like C4D cloner object. I loved it, i don't see why there's no standard tool that behaves live that.
We use the library shown in this video:
GDL Developer
Experimenting with API
from Brazil
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-20 02:31 PM
Braza wrote:Thanks I'll try this
Hope that helps.
Random Tree.zip
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-20 03:22 PM
Erwin wrote:Thanks this looks fantastic
Are there any other gems like this that I should be aware of?
The presets are great too...
I wonder how many of these plants and trees can be added before AC starts to bog down?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-20 03:39 PM
For trees there are also archiradar libraries that create random trees every time you place one, as I recall.
Those are not free, but the price is very fair and I think you can get free updates.
www.leloup.nl
Windows 10 Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-07-20 04:08 PM
Erwin wrote:They look great for this type of work.
AC handles it quite fine, but render times increase a lot if you place many trees. We tend to use them for a bit more minimalist look (see attached below).
Thanks again and will check out Archiradar.
