mukster
Pocket door problem
Archicad 23, MAC platform, When I try to put in a pocket door object, it shows up as a wide opening. Can't adjust it to show as a simple 3; door with the pocket going into the wall. I'm sure there's a simple setting that I just can't find.
3 Replies 3
Guru
Not a possible configuration with the default Aus / Int libraries. Can you post a screenshot of the issue as well as what ever library you are using?
Ling
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
Stress Co_
What door object are you using?
Are you trying to do 3 panels that all pocket into the wall?
This is D1 Pocket 23:
Marc Corney, Architect
Red Canoe Architecture, P. A.
I think mukster might mean a 3 foot wide door rather then 3 panels - basically as Marc has shown.
But I may be wrong.
mukster,
Can you post an image of the door in plan or 3D with the settings as Marc has shown?
This will give us an idea of what is happening.
As you can see it seems to be working fine for Marc.
