‎2010-07-24
09:35 PM
‎2023-05-24
11:53 AM
Rubia Torres
‎2010-07-26 03:33 AM
‎2010-09-16 09:59 PM
‎2010-09-17 03:53 PM
‎2010-12-14 12:11 AM
‎2010-12-14 02:07 AM
‎2010-12-14 02:58 AM
ricki_faris wrote:This still doesn't work in 14 (at least not for me).
Another way:
If you're rendering the view in Archicad:
1 - Once the render is done select the image (either using the mouse to select the portion you want or CTRL A to select all)
2 - CTRL C or Copy from the Edit menu
3 - Open the Preview window in your library part and paste (CTRL V or from Edit menu)
‎2010-12-14 06:23 AM
Barry wrote:
My appologies it does work from the 3D render window (only).
You can't copy any other 3D or 2D view to use as your paste.
You have to use a screen capture program to get the image into the clipboard.
Archicad 14 for some reason does not copy an image to the clipboard even if the correct Registry entry is set.
‎2010-12-14 07:09 AM
ricki_faris wrote:Can't say I have tried that as it would be the long way around.
OK, so if you screen capture a view (such as plan or section, etc) and save it as an image (JPG, BMP, etc.) in your screen-capture program.... Then, if you open the saved image in Archicad, then Select All, Copy & Paste to your Preview Window? (I did this successfully with a demo version of 14)
