Project2{4} Usage
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-10-04
11:41 AM
2022-09-23
02:26 PM
Oleksandra Vakariuk
When using Project2{4}, is the second set of definitions the infinite cut plane settings as in the guide it says "...(numCutplanes+1)"? Anyway, I am trying to get a projection at a defined height through my object, but I seem to only get the uncut projection...
PROJECT2{4} 5, 90, !projection_code, angle, 0, 1+2, !useTransparency, statusParts, 1, !numCutplanes, b/2 + gs_fw_lower - gs_fw_upper, !cutplaneHeight1, ..., cutplaneHeightn, 2, 1+2+4+8+64, !method1, parts1, gs_fill_type, !cutFillIndex1, gs_fill_pen, gs_back_pen, !cutFillFgPen1, cutFillBgPen1, 0, 0, 0, !cutFillOrigoX1, cutFillOrigoY1, cutFillDirection1, gs_cut_pen, 1, !cutLinePen1, cutLineType1, 65, !projectedFillIndex1, 19, 19, !projectedFillFgPen1, projectedFillBgPen1, 0, 0, 0, !projectedFillOrigoX1, projectedFillOrigoY1, projectedFillDirection1, gs_pen_2D, 1, !projectedLinePen1, projectedLineType1 2, 1+2+4+8+64, !method1, parts1, gs_fill_type, !cutFillIndex1, gs_fill_pen, gs_back_pen, !cutFillFgPen1, cutFillBgPen1, 0, 0, 0, !cutFillOrigoX1, cutFillOrigoY1, cutFillDirection1, gs_cut_pen, 4, !cutLinePen1, cutLineType1, 65, !projectedFillIndex1, 19, 19, !projectedFillFgPen1, projectedFillBgPen1, 0, 0, 0, !projectedFillOrigoX1, projectedFillOrigoY1, projectedFillDirection1, gs_pen_2D, 4 !projectedLinePen1, projectedLineType1
Also, how do I go about defining the wall closure? Even just simple closing lines matching the wall cut lines.
Ling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-10-15 09:20 AM
Those lines are drawn manually in 2D. Project2 does not seem to show the edges of the Wallhole. I have manage to get a workable display of the Wallhole edges using a set of Planes to case the hole. They also allow me to set the material of the Wallhole. The down side of this is that these planes conflict with the wall itself in 3D...
I have now toggled these to show only in 2D. The wall hole has been resolved using the WallNiche command. Script can be found on this thread.
I found an page about the
fill gs_fill_type pen gs_cut_pen Project2{3} 5, 90, 3+32+4096, 1+2+8, gs_back_pen, 0, 0, 0
Ling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-10-15 09:49 AM
Make sure the cutting plane is in the correct position, angle and direction.
The example object in the HelpCenter works fine.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-10-15 11:50 AM
IF GLOB_CONTEXT = 2 THEN !Plan view SECT_FILL gs_fill_type, gs_fill_pen, gs_back_pen, gs_pen_2d CUTPLANE 0, (gs_fw_lower + gs_int_fw + 2*gs_louvre_width) If abs(gs_louvre_opening_angle) > 0 then If abs(gs_louvre_opening_angle) < 90 then gs_louvre_opening_angle = 45 endIf endIf If LouvreOri = "Horizontal" then Louvre_over = 0 endIf ENDIF
That is the code at the start of my 3D Script.
Ling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-10-16 03:09 AM
GLOB_VIEW_TYPE is the new command.
But I am not sure that will work because it is in your 3D script, and the 3D script is not used in plan view.
Yes the PROJECT2 is a projection of the 3D script, but I am not sure if it will invoke the GLOB_VIEW_TYPE = 2 in the 3D script.
If that makes sense.
Comment out that line and you should see if the PROJECT2 is working as you want it to.
I am not sure how you can invoke the CUTPLANE without experimenting myself.
In the example they have a manual switch which I guess you want to avoid.
I think this might be why there is the PROJECT2{4} where you set the cutplane and height in the command itself.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-10-16 04:02 AM
The Cutplane is defined at the start of the 3D script, same as in the example object. The only difference there, is that mine is only active in plan view, but even disabling that limitation does not solve the issue.
Project2{4} creates contours at the heights defined in the script rather than an exclusion zone. That is all I have manage to get and how I have interpreted the introduction page.
Ling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-10-16 04:37 AM
IF GLOB_VIEW_TYPE = 2 THEN !IF GLOB_CONTEXT = 2 THEN !!this one works as well but is deprecated !if bUseCutPlane then !!comment out the manual cutplane option addz A/10 cutplane{2} 60, bUseSameSurface del 1 !endif !!comment out the manual cutplane option endifBarry.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-10-29 09:39 AM
It would appear that Project2{4} does not take into consideration the
Ling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-10-29 10:03 AM
The cut planes are measured vertically from the X-Y plane regardless of the projection code, so you are seeing a side view with the horizontal cut planes.
Try it with a projection code of 6 (front axonometry) and you will see what you will see from the side.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-10-29 10:17 AM
Ling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-12-06 09:30 AM
So I have managed to get the symbolic representation to show the correct lines but the lines are all shown hairline... The pens used are the same between the Projection and Symbolic views. The Wallhole created by the window tool also takes the
On a side note, I am not sure why the wall beyond in the Projected view is not shown. Is it due to the interaction with the
Ling
