2005-06-10
06:56 PM
2023-05-24
12:48 PM
Rubia Torres
2005-06-11 05:42 AM
2005-06-11 07:42 AM
2005-06-11 09:38 AM
Wokka wrote:You have a chance, using the wall tool accessory, to read this value.
I just don't know how to apply "WALL_LENGTH_A" to make the object the right length.
2005-06-13 04:47 AM
Olivier wrote:Olivier,
Some ac_params can do this, and more, but unfortunatelly they are not documented.
2005-06-13 08:53 AM
2005-06-13 02:50 PM
Dan wrote:Dan,
Olivier,
I run across these "undocumented" issues all the time. I've seen several other threads referring to "undocumented" info. Do you have any idea how, or if, typical users can get access to this type of info???
2005-06-13 02:55 PM
F. wrote:Frank,
It should be possible to find the WALL LENGTH by a global Parameter. See GLOBALS.
The parameters are available in most environments. But it will return just the length of construction line. Length reducing intersections are and requestable.
2005-06-13 03:58 PM
