Scaling objects
Red
Isn't there a way to scale an object to each stories scale? The problem is that the object was drawn on 1:1 and then saved as a object, but once it is placed on a 1/4" = 1'-0" then of course the text is right but the drawing is still 1:1. How can I correct this?
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
3 REPLIES 3
TomWaltz
Ideally, you should make the object at 1:1 scale.
Then, make the first line MUL2 GLOB_SCALE, GLOB_SCALE, which multiplies the entire object by the current scale.
Otherwise, you could use GLOB_SCALE / (whatever scale you made it at) to adjust for the same thing.
Tom Waltz
Djordje
Waitwaitwait ...
What do you mean by storey scale?
EVERYTHING has to be 1:1. The scale is for representation only.
You problem might be that the object is not scale sensitive, or that it is scripted as not scale sensitive (e.g it keeps the "printed size" - for example, title blocks)
Can you clarify?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Red
Thanks..... That fixed the problem.
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
