Proud Coarse Window Object
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2005-06-10
06:56 PM
2023-05-24
12:48 PM
Rubia Torres
I'd like to create a window object that sticks to a wall but is actually a proud coarse of brickwork so it sticks out like a square sill. It needs however to run the entire length of the wall, (a bit like reveal maker that I've seen advertised, but I don't think it will extrude off the wall) so I'd like to get the walls length. I know it is listed as:
WALL_LENGTH_A but how do I get my object to react to it? GDL Reference say's it is only for listing.
Any help would be great or is there a part out there I can get??
Thanks
3 D E N V I R O N M E N T
http://www.3de.com.au
Windows 11 Pro 64bit
ArchiCad 4.55>27 AUS
Lumion 12.5/2023
D5 Render
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-06-11 05:42 AM
OSX 10.15.6 [Catalina] : Archicad 22 : 15" MacBook Pro 2019 [/size]
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-06-11 07:42 AM
I can certainly build the object OK, it's making its length the same as the wall it's inserted into that I need to work out.
I make the origin of the object the start of the wall by using X~, then I just need to make it the length of the wall. I just don't know how to apply "WALL_LENGTH_A" to make the object the right length.
Cheers
Lumion 12.5/2023
D5 Render
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-06-11 09:38 AM
Wokka wrote:You have a chance, using the wall tool accessory, to read this value.
Some ac_params can do this, and more, but unfortunatelly they are not documented.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-06-13 04:47 AM
Olivier wrote:Olivier,
I run across these "undocumented" issues all the time. I've seen several other threads referring to "undocumented" info. Do you have any idea how, or if, typical users can get access to this type of info???
Dan K
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-06-13 08:53 AM
The parameters are available in most environments. But it will return just the length of construction line. Length reducing intersections are and requestable.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-06-13 02:50 PM
Dan wrote:Dan,
Olivier,
Unfortunatelly, i don't have special info.
Take a look at this thread;
More than two years later, it should be time to get access to some basics!
One hand, this culture of secret exists since the beginning of AC.
Other hand, i notice real progress in documentation these last years, look at;
and;
http://www.graphisoft.com/support/archicad/archiguide/
I suppose you already know these links.
We have to be patient for further info, but there is hope.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-06-13 02:55 PM
F. wrote:Frank,
It should be possible to find the WALL LENGTH by a global Parameter. See GLOBALS.
Can you tell us more?
I can't find a simple way to achieve this with GLOBALS or request function.
ac_wall_length param can read the wall length, you just have to use and adapt the Wall Tool Accessory, not so easy.
Am i missing something?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-06-13 03:58 PM
TAN(WALL_INCL) = (W2-W1)/L or
which is described in the GLOBALs-link above. The values of W1 and W2 you find in WALL_START_THICKNESS and WALL_END_THICKNESS from AC 8.0 on.
For inclined Walls you can use:
WALL_LENGTH=(WALL_END_THICKNESS-WALL_START_THICKNESS)/TAN(WALL_INCL)
But this does not work in case of WALL_INCL=0.
Sorry again. More I can't find so far. But I have to think about this issue in the next month anyway. If I find a way, I will post it here.
