REQUEST ("ASSOCLP_NAME" messing with Parameter script
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2020-05-02
04:15 AM
‎2023-05-24
11:30 AM
Rubia Torres
‎2020-05-02
04:15 AM
For the Object options, I'm reading the object name, then filling the options based on what object is attached. However, for some reason, the REQUEST ("ASSOCLP_PARVALUE...) command is screwing with the VALUES{2} command in the parameter script.
Even though the arrays are filling just the same, it doesn't work.
Code that doesn't work:
! Parameter script VALUES{2} "surface_type" surfaceTypeIndex, surfaceTypeDesc
! Master Scipt DIM surfaceTypeDesc[], surfaceTypeIndex[], surfaceTypeValue[] ELEM_TYPE_OBJECT = 1 iM = 1 ! Object surfaces IF GLOB_ELEM_TYPE = ELEM_TYPE_OBJECT THEN isValidType = 1 isComplex = 1 ! Used to turn on manual select surfaceTypeDesc[iM] = "Object Override Surface" surfaceTypeIndex[iM] = 1 surfaceTypeValue[surfaceTypeIndex[iM]]= SYMB_MAT iM=iM+1 partName = "" n = REQUEST ("ASSOCLP_NAME", "", partName) IF partName = "19050 Window reveal" THEN surfaceTypeDesc[iM] = "Inner blind Surface" surfaceTypeIndex[iM] = 2 n = REQUEST("ASSOCLP_PARVALUE", "blind_inner_mat", reqNameIndex, reqType, reqFlags, reqDim1, reqDim2, reqSurf) surfaceTypeValue[surfaceTypeIndex[iM]]= reqSurf iM=iM+1 surfaceTypeDesc[iM] = "Outer blind Surface" surfaceTypeIndex[iM] = 3 n = REQUEST("ASSOCLP_PARVALUE", "blind_outer_mat", reqNameIndex, reqType, reqFlags, reqDim1, reqDim2, reqSurf) surfaceTypeValue[surfaceTypeIndex[iM]]= reqSurf iM=iM+1 ENDIF print surfaceTypeIndex print surfaceTypeDesc print surfaceTypeValue ENDIF
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Mindmeister Mindmap
-- since v8.1 --
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-05-02 04:22 AM
‎2020-05-02
04:22 AM
Now if I just change these two lines of code in the Master script - it works.
The arrays surfaceTypeDesc[], surfaceTypeIndex[], surfaceTypeValue[] report the same values in both cases (as far as I can tell) - but in the first instance, I only get the option "Object Override Surface", but in the second option above, I get all three. See attached images.
partName = "19050 Window reveal" ! n = REQUEST ("ASSOCLP_NAME", "", partName)
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Mindmeister Mindmap
-- since v8.1 --
