Railing Post Ends
ksjhawk
Is there a way to gat what I describe in the attached PDF? While the railing tool has a lot of positives, we do a fair number of custom barstock railings and we get very specific about where the posts go. I have tried separating the segments, but my biggest problem is the ends of a segment are always treated the same. In some cases, I'd like to have one post at a node (transitioning from landing to stair run) and in other cases would like the end to place two posts either side of a node (as in the corner of the landing).
Is there an easier way to do this or should I go back to columns for rail posts so I can put them right where I want them? Also, is there a way to adjust the inner posts (to line up with treads for instance)?
Thanks...
MacBook Pro Apple M4 Max 128GB ram
OS X 15.7.2
AC29 - AC6.5
5 REPLIES 5
Bruce
I'm new to figuring out this railing stuff too, so apologies if I tell you stuff you've already tried. However, play with the settings in the following three areas to see if it achieves what you want:
1. Segment > Railings on associated stairs
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Bruce
2. Inner Posts > Single or duplicate inner posts
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Bruce
3a. Nodes > Number of posts and offset
3b. Nodes > Pattern continuity
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
ksjhawk,
In Railing Editing Mode, select any Post of the Railing, then right-click and use the "Convert Pattern to Segment Length" option. This way each Post will be treated individually and you can select one Post, and set it to a single post, then select another Post and set it to Double Post.
2raarchitecture
It looks like most things have to be edited on  edit mode for them to work...stating the obvious. I have tried to edit objects on the settings, but it was better to move things around on edit mode.
2RA Building Workshop
www.2rabldgworkshop.com
11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz. 16.0 GB. NVIDIA GeForce RTX 3060 Laptop GPU.
ArchiCAD 25. 5002 USA Full
