Is there a way to gat what I describe in the attached PDF? While the railing tool has a lot of positives, we do a fair number of custom barstock railings and we get very specific about where the posts go. I have tried separating the segments, but my biggest problem is the ends of a segment are always treated the same. In some cases, I'd like to have one post at a node (transitioning from landing to stair run) and in other cases would like the end to place two posts either side of a node (as in the corner of the landing).
Is there an easier way to do this or should I go back to columns for rail posts so I can put them right where I want them? Also, is there a way to adjust the inner posts (to line up with treads for instance)?
Thanks...
MacBook Pro Apple M4 Max 128GB ram
OS X 13.6.7
AC28 - AC6.5
