2007-07-07 07:13 PM
2007-07-10 10:46 PM
James wrote:I notice James and Matthew are on Mac, so this may be an issue with the dmg. (My ISP slows me down after so many MB of downloads, and so I can't get the dmg today to check...maybe tomorrow.)
Anyone else missing all the lights in the Lightworks library?
2007-07-10 11:13 PM
2007-07-11 12:42 AM
2007-07-11 02:45 AM
Matthew wrote:Probably didn't fix the dupe hotspot ID bug though.
I just copied them over from the old one.
2007-07-11 12:17 PM
2007-07-11 04:51 PM
rob2218 wrote:You can put it anywhere you like and load it in the Library Manager. If you just replace your existing library (presumably in the ArchiCAD application folder) it will be found and loaded automatically (as long as you don't change the name). If you do replace the old one, make sure you have he LightWorks lamps in the new library first.
I started a topic on this not knowing there was already a "LIBRARY" thread going on.
So, how and what do I do with all the LIB and other files that are contained in the zip file? Once I download the library zip file, where do I extract the contents of that zip within the C:/Programs/Graphisoft folder structure?
2007-07-11 05:02 PM
2007-07-11 05:08 PM
Karl wrote:Karl, you must be tweaking your library
Hmmm...but this doesn't work anyway: I've installed the new library, and it still tells me I'm out of date and need to download the update. (The famous "Jan 1, 1970" library message.)
2007-07-11 09:23 PM
gkmethy wrote:Thanks, Greg...one step closer to solving this!
Karl, you must be tweaking your libraryand you probably have 2 LCF files in your ArchiCAD 11 Library folder. The update checks the creation date of the LCF file, and if there are two, it can't decide which is OK, so it sends a "0" time stamp (which translates to 1970-01-01 in the Unix world) to the server. We have corrected how the server reacts to it - it will report "date invalid" instead of 1970-01-01.
2007-07-11 09:25 PM
