‎2007-02-16 03:20 PM
‎2008-04-24 05:32 AM
‎2008-04-24 11:09 PM
Jeff wrote:OBJECTiVE provides a tool specifically for this purpose. It can rotate a wide variety of objects about the axis you define, including standard GDL objects of your own making. You can also rotate in section/elevation windows. Take a look at
The rotate tool under the edit move command rotates the object about the Z-axis. I’m looking for a way to rotate the group originally in the xy direction about the X-axis to turn the top view into a side view.
‎2008-04-24 11:17 PM
tdellaqu wrote:Whoops - I didn't notice this was the most recent query on this thread.
I think I have a similar problem. I'm in elevation, and I'd like to rotate a floor slab for an auditorium space. Unfortunately, most of the move/reshape options are greyed out. I'm new, I'm sure there's a simple solution.
