Is there any way to make edges of RULEDSHELL generated objects make invisible? I have to eleminate the edges of starting and ending plane or the generating polylines. The normal RULED command has a separet mask parameter, which is missing in the RULEDSHELL command.
The GDL manual does not say anything about mask parameters.
Changing the status values does not change the visibility of the edges.
Maybe you should try a cutting command with invisible edges as workaround.
