Frank Beister
Ruled shells
Is there any way to make edges of RULEDSHELL generated objects make invisible? I have to eleminate the edges of starting and ending plane or the generating polylines. The normal RULED command has a separet mask parameter, which is missing in the RULEDSHELL command.
Can anyone share his experinces?
... und im Übrigen bin ich der Meinung, dass Trockenbauwände einschichtig zu modellieren sind.
1 Reply 1
Jochen Suehlo
The GDL manual does not say anything about mask parameters.
Changing the status values does not change the visibility of the edges.
Maybe you should try a cutting command with invisible edges as workaround.
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
