ā2005-08-02 09:44 PM
ā2005-08-03 01:09 AM
ā2005-08-03 09:58 PM
Ransom wrote:What template? I do not know what you mean by template?
Are you having trouble when using the new template?.
Ransom wrote:If I could find out what object is the problem then I could replace it with a SE Library object. Is there a way buy knowiny the error what object is the problem object?
You might also try putting in an empty window and then deleting it and trying again with one of the SE windows.
ā2005-09-02 07:31 PM
ā2005-09-02 08:07 PM
Joseph wrote:more often than not, a Polygon Degenerated error means that some parameter, somewhere in the object is set to 0.... finding it is not always so easy!
I instaled the new SE Library, now when trying to generate any section or elevation I get the error Ploygon is degenarated @ line 277 of file wa_frame_us_10.gsm.
Can anyone guid me on what object it maybe so I do not use it for now?
When I load the ArchiCAD Library 9.pla everything is fine.
Thanks,
Joseph
ā2005-09-02 08:29 PM
ā2005-09-15 04:54 PM
