Save 3D model in AC15 vs. save selection as object in AC16
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2012-12-04 04:14 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-12-14 01:16 PM
We have an existing entry about the development of this function in our database (#143140); I added your remark to it. Your ideas are appreciated.
Best regards,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-12-14 01:56 PM
ahmet wrote:You can change the 2D presentation to an editable 2D Symbol by following the method I outlined here:
The only reason I actually need the uneditable option is not only because it is small in size, but one can edit the 2D presentation and make it look as one desires.
2D symbol of Archibase.net objects
David
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-12-14 02:28 PM
We have an existing entry about the development of this functionMy comment was no request for a function, but a bug report: In AC16 is in "save as" dialog a button to save "binary", but it does not do so, if you select it. Delete or grey out this function or make it work. Something for a hotfix. IMHO.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-12-14 03:07 PM
The design issue in our database contains the same intention, although similar changes on the user interface can be achieved in a new release of ArchiCAD only.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-12-14 10:16 PM
If this is also "by design", what is the registry key for?
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-12-18 02:14 PM
That sounds interesting. The registry key enables the "Options" button in the Save Object dialog only, but the function should work the same way as in ArchiCAD 15. I checked the object saving in both versions, but didn't realize the difference as you did.
In case you can reproduce the issue, please forward both objects (one saved in GDL script, the other in binary format) to you your local reseller , and we will check them.
Thank you,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-09-26 10:48 AM
... as the functionality and the workflow are again destroyed by the "improvements"
The workflow I am referring to is that the whole buildings of a building complex can be required to be objects. In that case, Binary is ideal, as it is NOT NEEDED to have parameters active. The current scenario of object saving only pertains to doors, windows, their panels and handles, and furniture. It does NOT support any large scale project implementation.
Don't say Modules, that is another story altogether. They don't update, only when opening the host file (16 3872)
1. ArchiCAD 16 Build 3872
- default object saving from the 3D window results in missing parts and macros
- activating the binary save in the Registry results in the object without doors and windows
2. ArchiCAD 17 Build 4005
- default object saving from the 3D window yields exactly the same results
- there is not even a greyed out button for the Binary save
Modules? the same, only worse - they don't react to layer combos.
All in all, the functionality that WAS there is NOT THERE any more. Thanks. I am off to model an X Fighter to cool down, maybe I can submit it to the authorities and get the building permit?
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-11-07 12:47 PM
Not only that the "Binary" version comes up with an invalid 3d script so doesn't display in 3d at all because it is looking for other Library Objects that are in a different Library which I was avoiding loading as it has a lot of stuff I don't need hence my reason for trying to create a Binary version, grrrr
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-11-07 02:20 PM
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-11-08 12:20 AM
Djordje wrote:Dear Djordje,
... I am off to model an X Fighter to cool down,
Please share it.
May the force be with you
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
