Tom Krowka
Scale Sensitive setting
Is there anyplace to change the parameters of "Scale sensitve" in an overall sense. I'd like to change the setting from 1/4" to 3/16" so that doors and windows show trim in 3/16". I know I can change from scale sensitive to detailed in the door and window setting itself, but was wondering if there is a global setting.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
2 Replies 2
There is no such Global setting.
Each Viewpoint (Floor Plan, Sections/Elevations etc.) has their own scale when you go there.
Maybe you can create Clone folders in the View Map with the exact scale you want stored and always activate the appropriate view in that Clone folder when you need it.
Link
I think he's referring to the actual sensitivity, rather than the scale. AFAIK, there's no way to do it Tom.
Link.
