‎2014-03-22 12:18 PM
‎2014-03-24 04:16 PM
‎2014-05-20 01:01 PM
Barry wrote:Brilliant. I have just used this to capture the global North Direction into a Library Element parameter, so I can pick it up in a Schedule.
Just setting the parameter does not actually set the variable value for use in the script - which is why you have to open the object so it can read the parameter value.
