We value your input!
Scale sensitivity not updating
Gary Lawes
Hi All,
I have a simple 2D object that I wish to be scale sensitive. However it does not update itself automatically when the drawing scale is changed. If I open the object dialogue dialogue box and close it, the object updates as I would expect it to, but it does not react to a change in drawing scale automatically as it should.
My question is. Has a setting been introduced that controls whether or not an object reacts to a scale change. If so what is it?
Thanks
Gary
AC 17
Windows 7 Pro
Intel i7-2600
16GB RAM
11 REPLIES 11
Gary Lawes
Brilliant thank you Barry. Works perfectly now.
Much appreciated
Gary
AC 17
Windows 7 Pro
Intel i7-2600
16GB RAM
stefan
Barry wrote:
Just setting the parameter does not actually set the variable value for use in the script - which is why you have to open the object so it can read the parameter value.
Brilliant. I have just used this to capture the global North Direction into a Library Element parameter, so I can pick it up in a Schedule.
Archicad-user since 1998
my Archicad Book
