‎2025-03-26
02:42 PM
‎2025-03-27
01:58 AM
I placed several instances of the global coordinate objects. When I schedule them, I get only the Z value corresponding to the settings I selected in the objects.
I have a problem and a suggestion :
Problem: Why are X and Y values aren't displayed in the schedule? (
Suggestion :
What should I add to the object script to show in plan the Z value referring to Sea level AND underneath the Z value referring to zero project ?
‎2025-04-08 09:28 PM
So far i didn't get it to work,
Any suggestions please?
‎2025-04-09 10:38 AM
If you converted it from a 2D symbol to a 3D element, even if it is invisible in 3D, you would then just be able to autotext pZero?
Ling.
‎2025-04-10 07:48 PM
yes i can label it and show the Z value with autotext, but in schedule , it doesn't show the value
‎2025-04-11 03:19 AM
The complicated route then would be to REQUEST your Home Storey and your Storey Structure. You can then use these values together with ZZYZX to calculate pZero. Once stored in a new Parameter you should be able to schedule it.
Ling.
