Script 2D: visualize custom parameter
mest79
I created an object with a custom text parameter "name_family" that indicates the category of the object (external, internal, etc.).
Can I view the text of this parameter in 2D?
For example, for the height of my object, in the 2D script I have this command
IF GLOB_SCALE = 51 THEN
text2 0.35, 0.17, STR("%0.2m", SYMB_POS_Z)
ENDIF
Thanks!
Architect
AC22 (3006) - i7-6820HQ, 16Gb, AMD FirePRO W5130, WIN10
Guru
You should just be able to replace your string variable with your parameter name. Depending on the text, you might need to first assign it to a Textblock then assign that to the Text2.
If _return = 1 then
		SET STYLE Standard
		rot2 90
		add2 0, ProWidth / 2
		t = (hLength - hLength2) / 2
		text2 t, 0, ProLengthT
		DEL 2
endIF
That is a segment in one of my objects to display the parameter "ProLengthT" centred on the object.
Ling.
Guru
If _return = 1 then
		SET STYLE Standard
		rot2 90
		DEL 2
endIF
Ling.
mest79
Thanks!
Architect
