mest79
Script 2D: visualize custom parameter
I created an object with a custom text parameter "name_family" that indicates the category of the object (external, internal, etc.).
Can I view the text of this parameter in 2D?
For example, for the height of my object, in the 2D script I have this command
IF GLOB_SCALE = 51 THEN
text2 0.35, 0.17, STR("%0.2m", SYMB_POS_Z)
ENDIF
Thanks!
Architect
AC22 (3006) - i7-6820HQ, 16Gb, AMD FirePRO W5130, WIN10
1 Solution
Lingwisyer
Guru
You should just be able to replace your string variable with your parameter name. Depending on the text, you might need to first assign it to a Textblock then assign that to the Text2.
If _return = 1 then
		SET STYLE Standard
		rot2 90
		add2 0, ProWidth / 2
		t = (hLength - hLength2) / 2
		text2 t, 0, ProLengthT
		DEL 2
endIF
That is a segment in one of my objects to display the parameter "ProLengthT" centred on the object.
Ling.
Go to post
2 Replies 2
Lingwisyer
Guru
If _return = 1 then
		SET STYLE Standard
		rot2 90
		DEL 2
endIF
Ling.
mest79
Thanks!
Architect
