rob2218
Shower Drain pan with drain in the center?
anyone have one?
a shower drain pan object that indicates the drain in the "center" as opposed to the last releases drains showing on the edge or corner?
thanks.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
12 Replies 12
Erwin Edel
I have this option in ArchiCAD 18 at least. You can change the symbol type of the shower object (not the one with the panels, taps etc, oddly enough).
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
rob2218
well...will you look at that!
I like the fact that you can put a drain "in the center"...that's awesome!...now I can only get a "square drain symbol" or am I asking too much of this object?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Erwin Edel
Well, this is the Dutch localisation, but I would assume it is pretty much the same in the US library, except in inches hehe
If not, you should be able to grab the international library from bimcomponents.com: https://bimcomponents.com/Search/shower%20tray
www.leloup.nl
rob2218
thanks for the bimportal link.
i'll peruse thru there...see if there's anything available.
wondering if an additional "square drain" parametric could be plugged into the objects GDL? hummm.....
i>u
Edgewater, FL!
SOFTWARE VERSION:
Erwin Edel
If all else fails, patch it up with a 2d symbol of your own!
I had a look in ArchiCAD17 for this one, and it works the same as in 18 (the option to show it in middle).
https://bimcomponents.com/GSM/Details/16771
www.leloup.nl
rob2218
yes, I'm fine the way the AC18 object works...yes, have thought about patching it with a 2D "X" type symbol but I just hate doing that so....it reminds me of using "white out" then drawing on top of the white out.....UGGHH....
i>u
Edgewater, FL!
SOFTWARE VERSION:
Erwin Edel
We have an ever growing library of our own 2d symbols. Sometimes I make them 'stretchy' with doing a bit of coding, if I would end up having to re-draw it too many times for different variations.
It's mostly a consideration of how many times will it repeat, would I use it in future projects, does it have to be 3d? etc etc
With the morph tool even doing some one-off 3d modifying and then saving as object is quite easy. You get the basic parameters for pens and surfaces and fills and the like saved in. It's just not stretchable in intelligent ways, generally.
It is more 'fun' when everything is working out of the box, of course!
www.leloup.nl
rob2218
hummm....the morph tool huh? I think I'll experiment with it some day this week.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Erich
This one doesn't have the square drain, but it does most things you need.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
