2026-06-26
03:55 AM
2026-06-28
10:37 AM
Hi there,
I would like to add a vertical mullion that splits the glazing above the sliding door. How would I do this? The name of the door I am using is "sliding door with Transom".
Solved! Go to Solution.
2026-06-26
04:18 AM
2026-06-28
10:44 AM
You should probably have a quick flick through the settings of the objects in question before posting here. You would probably save yourself some time.
2026-06-26
04:18 AM
2026-06-28
10:44 AM
2026-06-26 04:27 AM
Thankyou. I tried the H-V Grid and that didn't work but then tried Divided Frame and that worked perfectly.
Best,
Clauds
