Slow GDL editor ArchiCAD 16
I have found the ArchiCAD 16 GDL editor to be extremely slow. Too
laggy for any productive work.
Just opening any GDL editor window or editing 2D symbol makes the
program consume a huge amount of memory and you have to wait
a minute just to change between windows.
If you create a new object everything works fine until you save it
the first time, after that it's laggy again.
Does anyone else have this problem?
The picture below shows memory consumption. Upper one happens
when changing between windows.
6 REPLIES 6
Hi Juha,
did you mean (for example) from "Parameters" to "Master Script" window in GDL Editor?
No lags hear!
Hello Andro,
Thanks for response.
For example if I have 2D script and 3D script windows
open and just click another - it takes a minute to 'activate'
the clicked one. The GDL editor is very laggy in every action 😞
Regards, Juha
David Maudlin
Juha:
I am not experiencing any delays in the GDL editing environment, we are on the same operating system. I have no idea what could cause this.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
pejotu
Hi!
Experiencing the same here!
Juha, you're likely using the Finnish Archicad also? - could there be a language specific bug?
pejotu
Yep, switched to INT version of v16, no slowdown!
Hello pejotu,
Thanks for the tip. I must abandon the FIN version for a while.
