ā2011-02-11 10:52 AM
PRISM_ 14, rail_length, 0.045, -0.04811539936889, 15, 0.04144274961775, -0.03895038973231, 900, 0, 115.4793648758, 4001, 0.04818609361501, -0.03179645769075, 15, 0.06574793327563, -0.02074811205036, 900, 0, -211.6808401911, 4001, 0.0864952753737, -0.02056936776373, 15, -0.005905922275061, -0.06111603154502, 900, 0, -47.88603034617, 4001, 0.08613703059829, -0.1024694848116, 15, 0.06558004796178, -0.1043565827946, 900, 0, -180.7544340626, 4001, 0.045, -0.1059728438522, 15, 0.045, -0.04811539936889, -1Code for smoothed version:
PRISM_ 14, rail_length, 0.045, -0.04811539936889, 79, 0.04144274961775, -0.03895038973231, 900, 0, 115.4793648758, 4001, 0.04818609361501, -0.03179645769075, 79, 0.06574793327563, -0.02074811205036, 900, 0, -211.6808401911, 4001, 0.0864952753737, -0.02056936776373, 79, -0.005905922275061, -0.06111603154502, 900, 0, -47.88603034617, 4001, 0.08613703059829, -0.1024694848116, 79, 0.06558004796178, -0.1043565827946, 900, 0, -180.7544340626, 4001, 0.045, -0.1059728438522, 79, 0.045, -0.04811539936889, -1Any suggestions, or am I asking the impossible? A last resort is to add in an extra 'straight' face between the curves, but that increases to polycount so I'd rather not...
ā2011-02-11 11:48 AM
ā2011-02-11 02:28 PM
ā2011-02-11 03:07 PM
ā2011-02-11 04:34 PM
ā2011-02-11 04:46 PM
ā2011-02-11 07:21 PM
derekjackson wrote:It does make sense to use library parts if you need more advanced functions, but in this case you may want to go to named variables and hand coded profiles instead of the automatically generated coordinates.That's been the source of massive debate in the office. We're gojng with objects so we can have several profiles saved within one object, along with options to turn corners on and off.
x1 = 0.0
x2 = 0.1
x3 = 0.2
y1 = 0.0
y2 = 0.2
y3 = 0.4
Prism_ 6, length,
x1, y1, 15,
x2, y1, 79,
x3, y2, 1079,
x2, y3, 1079,
x1, y3, 15,
x1, y1, -1
ā2011-02-11 09:48 PM
toler 0.0002 put 0.0450, -0.0481, 15, 0.0451, -0.0481, 79, 0.0416, -0.0389, 900, 0.0493, -0.0329, 3000+79, 0.0653, -0.0203, 900, 0.0653, 0.0000, 3000+79, 0.0854, -0.0239, 3000+79, 0.0853, -0.0240, 15, ! rough 0.0854, -0.0241, 79, 0.0139, -0.0625, 900, 0.0854, -0.1009, 3000+79, 0.0853, -0.1010, 15, ! rough 0.0854, -0.1011, 79, 0.0653, -0.1047, 900, 0.0653, -0.1250, 3000+79, 0.0450, -0.1047, 3000+79, 0.0450, -0.0482, 79, 0.0450, -0.0481, -1 rotx 90 prism_ nsp/3, rail_length, get(nsp) del 1
ā2014-12-24 09:10 AM
ā2014-12-24 01:40 PM
another Moderator
