Stair Story Sensitive
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2013-06-21 04:09 AM
‎2013-06-21
04:09 AM
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-06-21 04:10 AM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-06-21 04:55 AM
‎2013-06-21
04:55 AM
It will depend a bit on the stair object that you are using.
All objects can behave differently depending on how well (or not) they are scripted.
Place your stair in the basement storey and set it to show one storey up (looks like you have done that).
Now in the parameters look for option to "Hide treads from upper floor" and "hide treads from lower floor".
You may also have to play with the line type parameters for the treads as well because if they are all set to solid lines then you won't see any difference.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-06-21 05:22 AM
‎2013-06-21
05:22 AM
Ah ha... ok I'll give that a shot.
Cheers Barry
Cheers Barry
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-06-21 06:16 AM
‎2013-06-21
06:16 AM
Barry I can't get these stairs to look right at all, I'm going to delete them and start again.
Just so I understand better, when you activate the stairs tool, do the stairs get constructed from bottom to top, or top to bottom?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-06-21 06:41 AM
‎2013-06-21
06:41 AM
blimp wrote:I think most stairs are scripted with the intent of going up.
But just to complicate it some have the option for reversing the travel line.
It all depends on what stair object you are using.
The attached image is from a very old Archicad stair - not sure if it is still in the library but I assume it is.
I haven't looked at the latest library for a while.
