‎2008-11-10 08:28 PM
‎2008-11-10 10:12 PM
‎2008-11-13 09:17 PM
Karl wrote:Yes, after the introduction of the Grid Tool in AC10, they took the ability to create and specify a customized Grid Element away in AC11. Supposedly, GS decided that the GDL code was too complex for us mere mortals to handle...
The grid marker appears to be hard-coded into the application, so there's not much you can do.
‎2012-01-18 01:22 PM
‎2012-01-18 01:35 PM
another Moderator
another Moderator
‎2012-01-18 03:29 PM
ejrolon wrote:Thank you very much Eduardo.
The text within the grid will rotate automatically if you save the View with the orientation that you will use for printing.
If you rotate the view placed in the Layout it does not.
‎2012-01-26 06:44 PM
