By "stippled", do you mean "dashed"??? If so: there doesn't seem to be a line type parameter within the Parameters panel, so go to the Floor Plan and Section panel, make sure "Enable Object's Linetypes" is not checked, and set the "Symbol Lines" to the desired line type.
