‎2006-04-27 05:35 PM
‎2006-04-28 02:38 PM
‎2006-04-28 03:36 PM
‎2006-04-28 03:59 PM
‎2006-04-28 04:13 PM
‎2006-04-28 04:28 PM
Chadwick wrote:I'm not sure I agree that they do not work properly, since I have seen them work perfectly fine in some situations. I feel the problem is that they are not flexible enough for all situations.
Fine - but its still ridiculous. First off, I shouldnt have to learn how to be a coder to be an architect. Second, if the curtain wall tool doesn't work properly I feel that it should either A: not be included in the software or B: a note somewhere that says it doesn't work properly. Should I not assume when I purchase a seat of ArchiCAD that it wont do what it says it should? I think its ridiculous that I would have to spend an hour trying to figure out how to 'trick' the object into doing, not only what I want it to do, but what it should be doing in the first place. I don't really think this is too much to ask at all - especially from the leader in virtual building solutions.
‎2006-04-28 04:39 PM
‎2006-04-28 07:00 PM
‎2006-04-28 07:05 PM
Petros wrote:I agree 100 percent. Revit also has a robust curtain wall tool that allows you to make custom mullions and apply them where you would like, same for custom panels. You can create a custom curtain wall out of a series of 2D lines you set up - and it doesnt matter how crazy it is, it works. Furthermore, you can set the mullions to show different level of detail depending upon how close or far you are zoomed in/out.
I have said this before: try and find someone who uses ADT and ask him to demostrate it's CW tool. It can transform a polyline to a single CW
Petros
‎2006-04-28 07:58 PM
Joachim wrote:How can I find out what the prices are in USD?
I sell an object of a polygonal curtain wall.
You can find it here:
http://www.b-prisma.de/english/bibliothek/index.html?c~2
and a demo:
http://www.b-prisma.de/english/zip/pfost4.zip
