Read more
Tamborine doors
KeesW
Has anybody come across a Tamborine door object? I need one for an internal laundry recess, about 2100 highx1200 wide.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
8 REPLIES 8
What is a tamborine door? Is that one that rattles?
Could it be Tambour door?
Then garage door from the library should work.
KeesW
Thank you Anton.
I thought that the Garage door options were too crude for a joinery item.
Your spelling is better than mine!
Does this mean you are still looking?
KeesW
Maybe not. I did try a garage roller door before and the jambs and rollers seemed very big and bulky, and the slats were too thick and wide. I'll try to tweak such a door and see what I get.
If it won't work — PM me and I can build an object for you, as long as you know what you want (drawings are helpful).
Erwin Edel
There are some manufacturer objects for garage doors on bimobject.com, maybe they have one that works for you.
When I finally gave up in some past project, I've used a curtainwall to mock up the panel I liked and put it in an empty door opening.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
You might be able to use the tambour cabinet in the Cadimage cabinets, if you have that.
Richard
AC26 (since AC6.0), Win10
