Tapered Wallhole
Guru
Hi all,
How would you go about making a tapered void in a wall? I am wanting to use a window but it would appear that you cannot use a morph(?) as your WALLHOLE. I just get a box hole when I try... In GDL you could probably use a cutting object of the desired shape instead of a wallhole but is making it rather complicated...
Ling.
Guru
Hmooslechner wrote:
the possible workflow:
https://youtu.be/Tysfk2fTaIg
example EduAutAC22-Version:
https://www.dropbox.com/s/edr69y5fckueqdf/%20TAPERED%20WALLHOLE%20Window.pln?dl=0
Barry wrote:
Here is one with a curved slab with WALLNICHE ID.
I recommend placing the slab on the project origin - I didn't do that for this example hence the co-ordinates being away from '0'.
Given my current shape, there is no single convergence point... though that can be modified.
Thanks all,
Ling.
10 REPLIES 10
I would say that the 'WALLNICHE' would be the solution here.
It has a method to produce a pyramidal hole, so all you need is the shape (which you have) and what would be the apex point of the pyramid (which you will have to work out).
SEO
Guru
Having a million and one SOEs becomes troublesome once something changes...
Hmooslechner
I have just done a rectangular wallniche.
You will just need to add the points for your curved shape.
Guru
That is an idea Heimo. Did not think of building out the taper in a linear void...
Barry, that was written by AC? Where is the option to do a niche?
Ling.
I created a WALLHOLE (slab with ID) and then turned it into a WALLNICHE but I just tried and you can do the same if you call the ID WALLNICHE - it will create the WALLNICHE code correctly.
You just have to change the method to pyramidal and set the x,y,z co-ordinates for the apex.
Barry
Guru
Thanks all,
Ling.
