Bruce
Testing to Relative coordinates in GDL
How can I test the rotation of a 2D symbol I've scripted against the rotated screen orientation, as opposed to the original rotation?
I can't find anything in the GDL reference about rotated orientation.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
7 Replies 7
Use the TEXT2 GDL command in the 2D Script to display the SYMB_ROTANGLE global variable.
I suspect the orientation change will have no effect on the value returned by this variable but you should try to make sure.
TEXT2 0,0,SYMB_ROTANGLE
Edit: You may want to check out this post, Frank Breister mentions a bug related to exactly this GDL global variable.
http://archicad-talk.graphisoft.com/viewtopic.php?t=32721
Bruce
Yeah - this gives the rotation angle based on the default orientation. Ta anyway
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Ah, you want to do something that is always horizontal regardless of the orientation rotation?
Bruce
Yeah, something like that.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
I see.
I checked the GDL Docs for both AC13 and 14 and there does not seem to be such a GDL variable:
http://download.graphisoft.com/ftp/techsupport/documentation/developer_docs/BasicLibraryDoc/14/
You may want to create a wish for that.
Bruce
Aha! Found it.
Page 297 of the v13 GDL reference guide:
REQUEST ("view_rotangle", "", angleViewRotation)
Returns the rotation angle of the current view.
Cool
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Oh, that's good you found it.
I thought it should be a Global variable, I didn't think that it could also be obtained by a REQUEST function as well.
