2017-10-10 01:59 PM
2017-10-10 02:15 PM
2017-10-10 02:35 PM
2017-10-10 03:37 PM
Erwin wrote:The object is only for layouts so it works perfectly fine for that. The issue is if someone places it on plan for whatever reason and it multiplies only the text by glob_scale automatically. The 2D symbol around it still shows however it it's multiplied by glob_scale, and I don't want it to be. I didn't know if there was a way to stop the text from scaling automatically.
Also depending on the complexity of the object, I've found it quite easy to draw the 2D symbol and script layer visibilty in the 2D script to make the object parametric to my needs. This means you can just set up the text in the 2D window the way you like.
A couple of IF...THEN statements with FRAGMENT2 and a mul2 to stop mirroring is generally all I need for simple 2D objects like electrical symbols, fire safety etc
2017-10-10 03:44 PM
2017-10-10 03:51 PM
2017-10-10 07:04 PM
2017-10-11 03:03 AM
2017-10-11 03:30 PM
