Tuesday
Has anyone else had issues with switching projects and textures not linking anymore. I can't switch from one project to another with out closing the program completely. If I just open them with a project running I get the pink/purple and black square texture and missing doors and windows. It happened on version 29 also. 28 I was fine. Just the last two versions are the issue. If I don't notice the textures missing and save it will save like that and I can't get them to go back.
Operating system used: Windows 11 26H2
yesterday
Check your Library manager.
You should find there is a library that contains the textures that is missing.
You will need to load it.
yesterday - last edited yesterday
Given that all of the objects disappear as well, it looks as if your libraries are not loading, or that you are loading an old version of the library when the project used a newer version. Checking the library manager as Barry mentioned, and comparing it from when it works to when it does not should tell you.
An unlikely occurrence, but the model would not happen to be saved as a .mod would it?
Ling.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
yesterday
That worked. Said it was missing 21 and 28. Loaded 28 and cleared all my errors
