Typical Assembly Marker
I'm trying to find a way to either recode an existing section/elevation marker or insert a new one to look like the image attached here. Nobody in the office knows how to code but if its a simple code change it would be worth learning. It does need to be a dynamic marker, though, and not just an object, that I can make already.
Very simple triangular shape with a dynamic label inside. The label only needs to refer to the reference ID.
Does anybody know of a marker like this out there already?
10 REPLIES 10
Hooray Laura!!!!!! I got it!!!! thanks so much for your help that was maddening.
thanks again.
