2011-01-12 07:33 PM
2011-01-13 03:08 PM
if styp_m=1 then call Men_rest parameters ALL if styp_m=2 then call Men_ISA parameters ALL if styp_m=3 then call woMen_rest parameters ALL if styp_m=4 then call woMen_restisa parameters ALL if styp_m=5 then call rest parameters ALL if styp_m=7 then call stairs parameters ALL if styp_m=6 then call rest_isa parameters ALL if styp_m=8 then call no_smok parameters ALL if styp_m=9 then call isa parameters ALL if styp_m=10 then call fire parameters ALL if styp_m=11 then add .015,.04,.001 If gs_cust_p <> "" Then picture gs_cust_p, a-.03,zzyzx-0.08, 0 EndifSo when the standard sign types are selected, the script calls a macro to generate the 3D sign and text. When the Custom option is selected, just the bit map file is used, no 3D text is generated. It seems like the custom text option should have been disabled when selecting the Custom sign option. You could look at one of the macros to see about adding the custom text when the Custom sign option is selected, but it looks like the text would overlap part of the bit map, so some additional adjustments would need top be made.
2011-01-15 12:35 AM
