UI radiobutton edit
how I can edit in UI radiobutton, I want create choice with radiobutton, for exemple:
UI_RADIOBUTTON "exemple", 0, `Cyrcle`, 250, 20, 170, 20
UI_RADIOBUTTON "exemple", 1, `Cube`, 250, 40, 170, 20
UI_RADIOBUTTON "exemple", 2, `Pyramid`, 250, 60, 170, 20
UI Radiobutton work only 0 and 1, how I can add 3. atribut?
Or exist any similar way?
Please help me
7 REPLIES 7
The radio button is only an on/off switch (i.e. 0 or 1)
If you want a choice of multiple values then you will need to use the UI_INFIELD.
UI_INFIELD "name", x, y, width, height
Where "name" is the parameter that contains the VALUE list of your shapes.
But with infield I must use checkbox (In parameters Boolein. constant)
And if i want choice only one values, I must uncheck all other boxes.
Because I want use something like that.
Or what do you think with INFIELD?
Can you looked that on this my example?
If you want a choice of say "sphere", "cube" or "Pyramid" then create a text parameter fore "shape"
Then in the parameter list create a VALUE list ...
VALUES "shape" "sphere", "cube", "Pyramid"
Then I interface script ...
UI_INFIELD "shape", 20, 20, 100, 15
This way you can only ever have one shape chosen.
Otherwise if you are trying to use a radio button or check box you will need to add a routine that says if "sphere" is on then turn all the others off rather than turning them all off manually.
Erich
You can also do a grouping of bolean parameters with individual Infield and Outfield callouts - something like this (The uiX, uiY, uiLablelX1...etc. are just positioning variables):
	UI_OUTFIELD 'Continuous:',         uiX,  uiY, uiLabelX1, uiLabelY3, 1 : uiX = uiX + uiLabelX1 + uiGapX
	UI_INFIELD{3}  "bcont",            uiX,  uiY, uiButton1, uiLabelY3    : uiX = uiXs : uiY = uiY + uiLabelY3 + uiGapY
	UI_OUTFIELD 'Blocking:',           uiX,  uiY, uiLabelX1, uiLabelY3, 1 : uiX = uiX + uiLabelX1 + uiGapX
	UI_INFIELD{3}  "bblock",           uiX,  uiY, uiButton1, uiLabelY3    : uiX = uiXs : uiY = uiY + uiLabelY3 + uiGapY
	UI_OUTFIELD 'Finish:',             uiX,  uiY, uiLabelX1, uiLabelY3, 1 : uiX = uiX + uiLabelX1 + uiGapX
	UI_INFIELD{3}  "bfinish",          uiX,  uiY, uiButton1, uiLabelY3    : uiX = uiXs
Then in the master script you will want to add something like this:
!!               Radio Button Parameters
	bSetParams = 0
	IF GLOB_MODPAR_NAME = "bcont" THEN
		bcont   = 1
		bblock  = 0
		bfinish = 0
		bSetParams = 1
	ENDIF
	IF GLOB_MODPAR_NAME = "bblock" THEN
		bcont   = 0
		bblock  = 1
		bfinish = 0
		bSetParams = 1
	ENDIF
	IF GLOB_MODPAR_NAME = "bfinish" THEN
		bcont   = 0
		bblock  = 0
		bfinish = 1
		bSetParams = 1
	ENDIF
	IF bSetParams THEN
		PARAMETERS	bcont   = bcont,
					bblock  = bblock,
					bfinish = bfinish
	ENDIF
To contol your variables so that only one parameter can be selected at any time. This essentially creates a three way radio button that will look something like what you see in the attached image.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Radio buttons should work as nGhost suggested. Maybe
adding a value script does the trick?
!--value script
values "radiobutton" 0,1,2,3
!--UI-script
UI_RADIOBUTTON "radiobutton", 0, "Zero", 10, 140, 200, 20
UI_RADIOBUTTON "radiobutton", 1, "One", 10, 160, 200, 20
UI_RADIOBUTTON "radiobutton", 2, "Two", 10, 180, 200, 20
UI_RADIOBUTTON "radiobutton", 3, "Three", 10, 200, 200, 20
Here is the object
Thank you so much Juha Vesen.
This is it !!
