Unclear script of project2{4}
Nader Belal
Mentor
Hi everyone,
I was investigating project2{4} using the downloadable example supplied by Graphisoft in this page.
So by simple editing of the original script
for i = 1 to iCutPlanes
	put cutElevation + (i-1) * sliceHeight
next i
for i = 0 to iCutPlanes
	put 1+32,				! method
		2,					! parts
		1,					! cutFillIndex
		1,					! cutFillFgPen
		1,					! cutFillBgPen
		0.0,				! cutFillOrigoX
		0.0,				! cutFillOrigoY
		0.0,				! cutFillDirection
		1,					! cutLinePen
		1,					! cutLineType
		1,					! projectedFillIndex
		1,					! projectedFillFgPen
		1,					! projectedFillBgPen
		0.0,				! projectedFillOrigoX
		0.0,				! projectedFillOrigoY
		0.0,				! projectedFillDirection
		1,					! projectedLinePen
		1					! projectedLineType
next i
project2{4} 3, 270,
	0,					! useTransparency
	0,					! statusParts
	iCutPlanes,			! numCutplanes
	get (nsp)
It will provide this result in the 2D view
But when I reedit the script in the following way
project2{4} 3, 270,
	0,					! statusParts
	1,			! numCutplanes
	5000,
1+32,				! method
			2,					! parts
			1,					! cutFillIndex
			1,					! cutFillFgPen
			1,					! cutFillBgPen
			1,					! cutLinePen
			1,					! cutLineType
			1,					! projectedLineType
1+32,				! method
			2,					! parts
			1,					! cutFillIndex
			1,					! cutFillFgPen
			1,					! cutFillBgPen
			1,					! cutLinePen
			1,					! cutLineType
It simply doesn't work, the 2D space is empty.
Can someone explain me how to make this work ??
A good friend of mine have once told me that I“m so brute that I“m capable of creating a GDL script capable of creating GDLs.
12 REPLIES 12
Nader Belal
Mentor
Lingwisyer wrote:
Could you include an "If glob_view_type = 2" statement near the start of your script that will set all of your openings to the same height when viewed in plan? In this way you can cut them all with a single cutplane. No need to worry about overlapping shadings either.
Update
Just found out that you don't need a "cutplane" in the 3D Script as "project2{4}" already have it.
Lingwisyer
Guru
I was referring to the commands internal cutplane. The representation is different though as the internal cutplane will only use a single line type and weight whilst a stand alone cutplane will use the projected surfaces line types and weights. There are some other issues with using a standalone the the internal one solves, but I cannot remember what they were at the current moment...
Ling.
Nader Belal
Mentor
@Lingwisyer
I'm aware of that, I meant that the function doesn't need the cutplane for the objects' representations, unless ofcourse it's to bypass a limitation.
