Unwanted 2d lines show on plan
I made curved bleacher for a stadium we are designing. I made it using a custom profile and substracting the peripheral curved wall. Then I proceed to save a top view and saved the part as a gdl object. The problem is that in plan you see the vertical walls (risers)underneath the horizontal floors (treads). Is there a way to stop this from happening?
maybe saving another way, or opening the part and fiddling on the 2dl script? Thanks
Eduardo Rolon
Hola José,
Open the Object
and edit the 2d symbol as you wish
every hotspot you put will let you snap to it…
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
David Maudlin
José:
If the symbol is in the 2D Script, and you want to convert it to a 2D Symbol for editing, you might try the method I described here:
2D symbol of Archibase.net objects
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you very much. It did work.
