Unwanted geometry merge
Bruce
When creating two PRISM elements side by side with no gap between, is there a way to maintain a separating cut line?
The ArchiCAD default is to merge / clean up touching geometry - but I would like to maintain a separating line without having to create a gap between.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
11 REPLIES 11
The easiest way is to use two separate materials.
They can be identical materials but with different names.
Or leave a small gap in your model.
Bruce
Thought so. Would be very handy to set an intersection priority (sim to DRAWINDEX) so these workarounds wouldn't be required.
Thanks Barry.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
There might be more to it but I am not sure what.
Just checked one of my doors.
All PRISMS have the same material and no gaps.
Joining lines are not merging.
I can't see anything special in the code.
See attached image.
I also created a new object with two cubes (PRISMS) next to each other (touching) and the lines were there.
If I get the time I will look into it further unless someone else has an answer already.
Bruce
Thanks Barry.
Not a problem in elevation - it's section views that I'm interested in keeping the prisms separate.
Cheers.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Sorry I missed the 'Section' part.
Different materials won't help.
You will need to use 'SECT_FILL' command with different fills.
Again they can be identical fills so they look the same but with different names so you will see the join.
Bruce
Yes - that part I knew...but it won't help in this situation. I've just created a <0.1mm gap.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
I can't imagine why not but of course I am not familiar with your object.
All you need are two fills - the same with different names - i.e. "Solid Fill" & "100 %".
Then add a SECT_FILL before each PRISM command using a different fill for each adjacent prism.
If you have more than two adjacent prisms then you will need more fills as well.
Bruce
It's more to do with the office standards / attributes, and the fact that the users will be choosing the fills...not the coding functionality.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Ahh - I get it now.
