The GLOB_ID is a string rather than a number.
So I would say you would have to use the SPLIT command to filter out the number component.
However your GLOB_ID will always have to be in the same format - the user can type what ever they want in there.
Type something other than what is expected in the ID and the script won't work again.
I am guessing you would rather use the ID in the info box but you will be better off creating an parameter (integer) in the object that means only a number can be used.
You can even control the range of numbers allowed to block out negatives or zero values.
