‎2011-06-01 10:44 AM
‎2011-06-01 11:20 AM
‎2011-06-01 04:26 PM
‎2011-06-01 04:29 PM
‎2011-06-01 07:52 PM
‎2011-06-02 04:55 AM
Master wrote:I thought of this but then your object can't be placed as an object.
VBE allows you to walk through doors and windows. Solution: make your object a door or window. You can do this by assigning the subtype of door or window to your object. Open the object and view the main dialog. On the right above corner there is a button Select Subtype. Click it and browse to Model Element / Opening / Wall Opening / Door (Wall) and then OK.
